dstan
I bought a truck this past spring with a 71 440 and 727. I put about 600 miles on it and when shifting into second the tranny started completely locking up. I limped it the mile back to my house and parked it until i got another 727 for it. When i pulled it onto a trailer to get it to the shop it dumped all the atf and 1st went out as well. I found out the previous owner had not installed the kickdown linkage and figured that caused it to overheat and kill itself. I bought and installed a kickdown cable in my newer 727 and thought I was home free. I have put less than 200 miles on it and it dumped all of its atf on the interstate last night. It appears as though the main seal gave out.
I'm wondering if this one might be salvageable since it didn't seem to lock up like the last one did annd what could cause this. As far as I could tell it had been working flawlessly until this point (besides a slow leak from the front of the pan, I kept it topped off though). I'm considering switching to a manual if i have to replace it and was wondering how much it would cost to go from an automatic to a manual as well.
Any advice will be gratefully accepted. Thank you for your time.
