I wake up this morning drive to school. No problems.
Bell rings at school I go start car and put it in gear. Nothing happens.
I pulled the lines going to the radiator and went through the gears and nothing more than a drip came out.
Pulled her home, jacked her up and pulled the pan.
Fluid was disgusting and there is metal in the pan. Filter is soiled.
Is it normal for transmissions to just all of a sudden go out?
In the past I've had slippage or other signs before my trannys go...
What is your diagnoses?
I believe it to be the front pump.
