727 question ...
rebeldart
North FL
Any reason my car is near impossible to roll backwards in neutral / I removed the driveshaft tonight - rear end spins free, turning the driveshaft by hand I determined its the trans, forward is fairly easy, backwards, lots more resistance. Has something been damaged ? All is rebuilt (supposedly).
front clutch pac just a little tight probably....
but it does not move forward in neutral while it is running?
Haven't spent enough time with the car yet (drove once so far) Is this something I should check for, forward creep while in neutral ?
