727 Question?
1969GTS
I've got a new Northern Radiator here as I'm running hot with the engine and stall converter. The Rad I have isn't a 340 rad so its getting replaced. I have a transmission cooler and there is one in the new rad as well. I just want to make sure I've got my plumbing straight. Which is the outlet and which is the return line on the 727? I'm planning on going to the rad then the cooler before going back to the transmission, any issues with this sequence?
Thanks
