[Found!] 727 shift lever
1994redram
Oklahoma
I pulled the 225 slant/904 from my '70 dart and didn't keep the shift or kick down levers from it before I sold it. I'm going to be using the Lokar kick down cable setup and reusing the factory floor shifter. I need the correct levers shipped to 73169
I have the 273 Kickdown set up but I think I only have the pedal and levers to accelerator spring ifany help?/
If you're using the Lokar setup you're better off buying this kickdown lever from A&A Transmissions
Home - A&A Transmissions
Their phone # is on their site, call and order, I couldn't find the product on their site. If anyone knows an alternate source for this lever please chime in. It's the shortest lever on the market.
The Lokar cable's throw will most likely be off, or way off, if you use any other lever. You'll have to modify that lever by drilling additional holes in it until you get the throw right, or make an adapter at the carburetor to adjust the throw. With this lever it solves that and keeps it looking clean at the carburetor.
Don't forget to add a light return spring at the lever as well, it will most likely need it.
1gr8 trik I found is bring the cable threw the passenger side to avoid binding, just start it threw up top on passenger side and come around front of tranny , what a difference no tigh loops to bind
Go with AA trans for sure. Speak to Robert. Just tell him what you have and that you want the right levers. He's a great guy.
