727 tail shaft bushing install
Alecb
Sacramento
I had a local shop install new bushings in my 727 that I'm rebuilding. I understand the tail shaft bushing is supposed to point up to the 12 o'clock mark (sharpie mark) but the guy installed it pointing at the channel at the 8 o'clock position, where there is another channel. Will this be ok for fluid dispersion on the slip yoke? Should I have them take it out and reinstall it? Thanks in advance.
@Duster346 he can help, matter of fact he has a video on YouTube that you can watch to see it it's correct
If it needs to come out a new one needs to go in, don‘t reuse it.
That’s perfect.
(Ex trans builder.)
