727 tail shaft length
mike rat
Active Member
What is the proper tail shaft length for a 727 in a small block 71 duster? I am swapping a 340 in place of the stock / 6?
thanks Mike
i think they only had the long and short tail, you will need the long tail since the short tail version used a bolt in yoke and was used for truck and rv applications.
...................which means you'll need a shorter driveshaft, and while you are at it, what are you doing for a rear axle?
