Badart
Senior Member
I have recently aquired a later model 440/727 combo that came with my 66 Plymouth Fury III. I believe it came out of a motor home. I already have the correct pan and pickup for the engine. There is no slip yoke on the transmission ouput shaft and It is the wrong housing. I already have the correct housing. My question is, do I only need a new output shaft? Are there other parts that I will need also to convert to a slip yoke for the Fury?
I still need to pull the drive shaft and see if it is splined for the 727. I know that the car was orginally a 318 car, but I am not sure what transmission came in the car orginally 904/727? Any ideas? Here is a pic of the tail shaft.
