[WANTED] 727 tailhousing 89 Cummins truck 2wd
Getting ready to rebuild mine. Just curious, what happened to your housing ?
Get the proper motor plate and starter, shorten the drive line then just wire in a switch for the OD solenoid.
The cross member on the 2wd may be different between 727 and 518 not sure, I swap in a 4wd 518.
