I had a 727 rebuilt. The car was delivered with low pump pressures, seemed to be slipping. The guy put 12 springs in the fwd clutch in a trans that was basically a stock rebuild. He was supposed to put a trans-go tf-2 kit in it but didn't...don't know why.
Took the trans to a real shop. They found that the tail shaft housing snap ring had come out of it's groove and proceeded to chew up the shaft. All of the new alto red and steels were burnt. Will the snap ring coming loose create end play sufficient to cause clutch slip?? Or more, low pressures causing slippage??
