6671dartster
Active Member
I have a 71 Duster that I just bought a few weeks ago. Took it to have axle bearings put in and forund some issues with the transmission shifting properly. The car has a 727 trans and when you put the car in drive it stays in drive and starts out in drive. It does not kick down into low gear. Same if you pu it in 2nd, it starts in 2nd. I cant seem to get it into low gear. It has an aftermarket B&M quick shifter in it. The transmission does not slip, leak or make any noises. The guy I bought the car from said it has a shift kit. I do not want to gernade this tranny, so I have not drove the car. Any ideas would help, has any one experienced this? Message me back. Thanks:dontknow:
