Is anyone else running a 727 trans in your early A body? I just purchased my 66 cuda and it has a 318 roller motor and a 727 small block trans behind it. It seems to be a very tight fit. Just concerned about heat and such. Not much room to work around it either. I am switching the trans downshift linkage over to a cable system to give more clearance for the exhaust. Thinking maybe I should put a 904 back in the car.
