Robbie2734
Lambcharger
I've heard that the 727 (in the car now) uses more power then the 904. I've located a rebuildable 904 and want to know if it's worth doing the swap?
I agree ! That what I run. 360/904 w 2.74 and 4.10's. The difference IMO between the 2 is that the 727 will need less servicing in the long run. The 904 needs more TLC such as, regular fluid changes and inspection to live with the higher HP, other than that it's bullet proof to 500 Hp with minimal $. Where the 727 needs a driver that knows his trans and the overrunning clutch. I wont go there n start a trans "war". It's just my opinion and what do you want out of the car will also play a big part in your decision. IMO 400hp Street = 727 build it n forget it, it will run forever. Wanna go faster lighten up a bit to the 904, .3 can be a big boost when it comes to the line.in a car running mid 11s a 904 with 2,74 low gear is about 2 to 3 tenths faster in a small block.
