73 340 duster popping sound on passenger side
flathead31coupe
indianapolis indiana
Ever since I Have had the car.I noticed a popping sound When turning at low speed on the passenger side, I had a little time to look at it and I noticed Above the back , bolt of the cross member There is about a one inch crack going up the frame Not sure.What else is wrong yet?Until I get the front wheel off.And get her up in the air
Hard to say until you get it in the air. Make sure your idler arm and tie rod ends are tight as well.
So after further investigation, the crack wasn't that bad and easy. Fix the poppy noise.is still there ..narrowed it down. It seems like the upper ball joint on the passenger side It doesn't seem like it has any play. Could it be just that dry.... I will grease it tomorrow and see what happens
