340plot
the bushy bush
i have a 73 duster 340-3-speed. engine and trans are not in. it comes with a 69 340 and 4-speed. has dual racing mirrors, performance hood treatment, 7.25 posi. . the car is orig a 3 speed on the floor, but comes with the 4 speed. i have everything for the full trans , including all linkages, shifter, z-bar, bellhousing, shift rods, clutch flywheel........everything
the engine is a 69 340, that has no heads on it. i have the 202 j-heads, but they are bare. they have been checked for cracks and cleaned and prepped for new valves and all. i do not have anything for them. they are bare. i have not pulled any caps, but it spins over freely, and there was no mettalic particle in the oil. i am told it was a good running engine before they pulled it apart to put in this car.
car comes with a set of buckets that need to be recovered, but they had no tracks.
car need front floor pans, center spare tire area in trunk. not the whole thing. lower quarters are starting to bubble.
the frame rails are perfect. no rusting. all glass is good.
i have title and perfect fender tag. 3,400.00. located 30 minutes from martinsville international speedway in va
