'73 Center Link Question
lgjhn
"The faster you go, the faster you go..."
Southwest LA
I cleaned, blasted and painted my suspension parts and I'm now putting it all back together in my '73 Dart Sport. When I originally pulled the center link, I failed to identify which end was the pitman and which was the idler. Is the center link symmetrical? I've measured distances and hole sizes and it looks like it is. Before i put it all back together, I'd like to make sure.
Thanks.
I just did the same ..had two setups around here..i think they are symt..mine has the part number on the driv side away from idler from idler...
