73 Dart Upgraded Tie Rods
mario03srt
Hillsboro Oh 45133
All,
I finishing up my QA1 control arm and strut rod upgrades. I was also interested in upgrading the ties rods. I read over the article and it indicates tha a 1974 and up tie rod setup is used. Does any one have a good part number(s) for the assembly needed to swap out the stockers? Are the ends only replaced? I see that there is a QA1/UMI Sleeve. Is it more practical to swap out this than the ends?
Thanks,
Marion
Hi,
Which solid sleeve did you use? QA1? For what make and model? The C body end is 74 and up correct? Fury, Imperial, Newport.
Thanks,
Marion
Hi,
Thanks,
Marion
I don’t recall who made the sleeve. It’s aluminum and takes the 11/16 tie rods
Lately thinking about and up coming project, I've been considering solid adjusting sleeves. Although not that expensive, but an extra I might as well....$60/70, the current going rate for these new parts, I'm wondering if a few well placed tack welds down the center of some stock sleeve's would be beneficial.
