CultClassik
Just wanted to ask those of you that run the 73+ A body factory front discs. I am installing these now, but the rear seal on the bearing doesn't fit snug in the rotor. I've verified the part number and it shows good (I use a 75 Dart as reference for this and other parts). It's snug on the spindle, but a bit loose on the rotor side.
I would think it should snap in to the rotor and will spin on the spindle portion, correct?
