beebeeri000
Rest-O-Moder
hi i have a 73 duster and i have no heat at all when i turn the switch nothing happens. idk if its the switch or the heater blower but i really need heat so it's drivable
ok so i tested it and it didnt work at all. could it maybe be the resistor? or should i just go and get a blower motor? and does anyone know where i can get like a replacement for the wire for the like hot/cold controls? mines completely seized up
Go get a blower motor.
The wire you speak of.... Could that be the cable for the control door?
Check to make sure that it is not just bent/routed where it bends too much. Minimum bending is best. If not, then you need to find another cable.
Be careful when replacing the cable. The spring clip that holds them onto the mounting brackets can be difficult. then you end up breaking the bracket off of the housing and making a hole.... :banghead: :banghead: :banghead: :twisted:
Sometimes I think it'd be easier just to bolt a Maradyne heater to the firewall.
