I have a 73 Duster parts car painted yellow with good red fenders, doors, trunk lid ($30) and a decent straight body. It's an original 318 car so has the spool type V-8 K-frame ($100). The car has the original LBP disk brake setup while the rear is an 8 ¾ with the 489 case, sure grip, and 4.10 gears ($1500). The axles, I believe, are LBP aftermarket pieces with screw in studs and the brakes are fairly new. The hood ($30) is drilled out for the 73-style dual snorkel scoop that is also for sale ($400). Its an aftermarket unit that has been meticulously finished. The shift linkage and complete kickdown linkage for a 904 and 318 2-bbl application is available. All the window trim is there as is all the glass. The car has power steering and power brakes but the brake booster and master cylinder are gone. The booster brackets are still attached to the firewall. The gas tank and straps are in the trunk as is all the window trim and some of the plastic interior trim, horns, some dash pieces, arm rests, jack assembly ($30) and engine mounting brackets. There are a lot of other parts that are not listed but are in the car and the trunk and are available for sale so PM me with any needs. I also have a clear title for the car if someone wants the empty shell. Prices listed are plus shipping.
Ken
Edison, NJ
Ken
Edison, NJ
