[Found!] 73 power brake booster (MINT only)
Yorkman1
Norfolk,VA
Rating - 0%
0   0   0
Looking for a MINT 73 disk/drum combo power brake booster. With brackets is a HUGE plus. Must be correct anodized Zinc. LMK what you have!!!! Also if you only have a brackets from booster to inner fender/booster to firewall I need those as well.
I may have at least part of what you want. Many years ago I bought what appeared to be a new brake booster that I thought would fit my 69 Barracuda. As it turned out it was too big around and came in contact with my valve cover. Later I was told it is for a 73 A body and might work for you. Can you attach a picture of the booster you need looks like? If its what I have I will pm you. Sorry, all of have is the booster, not brackets
Yes I can! And that would be a
Booster would be great! Let me get a picture loaded up here!
Top is the OEM look. Gold zinc. That’s a NOS unit.
That is what it looks like on my car. Mine has no guts as you can see.
I have the brackets off a 74 Duster that should fit
