73+ sway bar tab location?
trbodrt
so. cal
I want to add a sway bar tab to my control arms but have no measurements, does anyone have dimensions that I could go off of for a 73+ sway bar, thanks Derek.
Will this work?
6 3/4" from centerline of lower bushing hole/pivot pin/lower bushing
Here:
Don't be afraid to reconfigure and move the tabs to fit your bar and ride height. You want the bar horizontal, with the connecting links vertical with weight on wheels.
Ummm....yeah, that is perfect, thank you very much. I have already rebuilt my lower control arms, would it be okay to weld on reinforcement plates and sway bar tabs with the pin and bushing installed or do you guys think the heat will have an effect on the rubber?
Do a little at a time with cooldown time between welds.
