805moparkid
Slant and AFX Guy
so what are you guys doing for gauges? im going with Autometer GS gauges, but not sure where they will all go. im going for the pro-touring look so the insert will be stock but probably modified. may have to go with A pillar or dash pad gauges.
what you guys got?!?!
P.S. going with in-dash speedo and tach, vac/boost gauge (yes may need the boost later), oil pressure, water temp, fuel level, trans temp, volt gauges...
