[Found!] 73-up a-body disc brake spindles
72Dodge
Milwaukee, WI
WTB pair of 73-up A-body DISC brake spindles and the bolts/nuts that hold on the ball joint.
DON'T need the ball joints, control arms, backing plates, caliper brackets, etc... JUST the spindles and ball joint bolts/nuts.
Has to be A-body, not FMJ body spindles
Thank you!
He is out of stock on these. I was hoping to get some sooner. Hoping someone has some originals with the hardware I mentioned I need also. Thanks though.
I bought a set from PST a few months ago, you could try them. They were more expensive than Doctor Diff but had them in stock
Same situation there. Also, I need the ball joint bolts/nuts, which I don't think they'd have. Thank you for the leads though.
To be more clear... the bolts and nuts I need are the ones that hold the ball joints to the spindles. I'm not talking about the castle nuts on the joints themselves. Each side has 2 bolts and 2 regular large nuts that hold the lower ball joint to the spindle. Those are the ones I need.
I have a set of original spindles. $150 plus ship.
Let me see if I can get some from closer, then if not, I'll get back to you. Would need the bolts/nuts to attach the ball joints too (but not the ball joints themselves). Thank you for your reply.
