73Duster chassis is up and running
[ame=http://i1123.photobucket.com/albums/l548/bigmike540/Mobile%20Uploads/Cut__id_001_zps7pwfkg9x.mp4]
th_Cut__id_001_zps7pwfkg9x.mp4
[/ame]
little better I guess ..wire broke on the shifter had to lift ..shiftniod had no power...car spins really bad but still moves good ..found the spinning problem that is being fixed...not really a problem but we know its going to spin with the ladder bars in the hole they are in so they will be moved up 1 hole ..this was only testing so it was still fun..
[/ame]
little better I think..on this hit had to lift shiftnoid wire broke car didn't shift...spin pretty bad but left pretty good ..ladder bars has to be moved up 1 hole they are in the bottom hole was just testing didn't want any problems with the car maybe want to lift the wheels or anything ..so going to move the bars up 1 hole shiftnoid is fixed now made a few little changes hope to be out soon ..
here wasn't a good day..car was loaded ran fine no problem in shop got to track went to get heat in the motor trans leaking ...we pulled the trans put new front pump bushing in back in car less then 2 hrs and still leaked ..got it home pulled pump the bushing behind the pump had moved ....
well that's about all for now hope to carry it to Henderson to the show on the 17th if all is well..in the air now but we will see..
