I'm looking for a nice rear bumper for my 74 Duster.May be interested in just the guards as a consolation prize.Also need two good tailight trim bezels. Thanks!!
I have a '75/'76 bumper which will interchange, but has the narrower bumper guards. It's in pretty good driver condition. I still need to get it out for a better inspection. But if interested in more info, let me know.
Yes I am interested.Mine has the narrow-strip guards that are different from the thicker ones on the front.Do you accept Paypal? Let me know when you get a look at it. Grocerboy@verizon.net Thanks...John
I may have found a bumper in Florida,but not certain yet.Stay in touch please.How much do you want for the light assemblies? Can you accept Paypal? Grocerboy@verizon.net Thanks...John Bell
It depends what year your car is. A '73 takes "conventional" bumper brackets and may also have a reinforcement between the brackets and bumper. If it's like the front on a '73 and '74 Duster, the reinforcement plate can be removed and the bumper can be bolted directly to the brackets.
1974-76 rear bumpers had the "shock absorber" brackets with a very heavy reinforcement sandwiched between them and the bumper. You can't remove the reinforcement plate because those bumpers won't bolt up to the "shock absorber" brackets. '73 bumpers have a different bolt pattern than '74-'76.
If your car is a '73 and you get the '74 & up brace and "shock absorber" brackets, you will need to do some fabricating to install them. I don't have anything to do a side-by-side comparison, but it won't be a bolt-in deal.
It's a totally different set-up and may weigh around 3 times as much!
