74 Dart /6 904
Honestly I don't know if it is a 74 or 75? If you say it's a 75 it's a 75.
Grille is '75/'76 and tailpanel is a '75 only. Front bumper also appears to be the type with shock absorber bumper brackets, which started in '75 for Dart Sports.
Hey Jefflock; I need the 904 - stock column, shift linkage.
specifically: 1) the rod from the column "tab", 2) the pivot assy (complete with trans mount bracket and frame bracket), 3) rod from the pivot assy to the shift lever.
My column is fine and I have the trans shift lever. Mike
how about the disc brake spindles and caliper brackets and dust shields with shipping to 90640 business address. Thanks
air cleaner for a 2 barrel how much for that and the washer bottle to 53590 wisc. how about the carb also is it still good dam hate to see a mopar crushed and the pentstar for my collection of 1 more fallen mopar
hate to see it crushed
what is the statues on the motor? was it running etc? Did the car come with a front sway bar? I have to rebuild the suspension of my scamp as well as engine and tranny. if the price is right and not sure the shipping cost to northern Ca. I might want the rear springs shock mounts upper and Lower control arms and Motor and tranny assuming the drive train is rebuildable, and what condition was the steering box? Is the wiring harness for the engine compartment worth anything & how about the wiring behind the dash and instrument cluster. Lastly the over flow and w.s washer reservoirs are they useable? my thought is to get the parts rebuild everything and then install on the car when I have everything and its all ready. maybe the radiator as well. thanks
