I would not add ANYTHING to ignition and would in fact go a step FURTHER. The "voltage drop" issue in these girls which causes OVER charging is very often an overall harness voltage drop in the circuit path to the VR. THIS CAN BE the connector and ignition switch IE both the switch connector and internal switch contacts.
Either splice into the ignition "run" wire and trigger a relay, or better yet, electrically cut the "run" wire coming out into the engine bay. Use the firewall end to trigger a relay, and use that relay output to feed the other end of the cut wire, that is, the underhood loads. Feed the relay power from a fuse/ breaker from the starter relay stud.
If the pump you are adding is not too large, and you have used at least no10 wire to feed the relay, you could also run the pump off that relay output. OR you can trigger a second relay to run the pump of that point
