74 Duster Sail panel swap
keenkeener
Active Member
Hi guys, Great site you have here! I am freshening up the interior on my 74 duster. I removed my sail panels to fix a crack in them and paint them only to break them about 3 times as much doing this, and then closed the garage door on them!!! Do the metal sail panels from the earlier dusters interchange?
Thanks!
Thanks!
Yes they will. Thats what I did on my 75 Duster.
Sorry...no they won't interchange directly. The "notch" for the pop out window is in a slightly different place. If you bring over the early tins, you need to bring over the windows too.
I've got a set of early metal ones that won't fit my 73 if your interested in buying them.....
This must be true. I had a 72 Demon parts car so I switched over all the good metal pats from it and through all the 75's plastic junk in the trash. If I remember right I did change over the pop out window and the latch from the 72 as well.
