[WANTED] 74 swinger 1/4 window rollers
I found the picture of the post with no roller on another post and it appears to be the same as mine. I took the panel off this weekend and the back roller appears to have broke. Also one bolt holding the glass appears to been backed out (loose) for some time now. Tried to remove it but thought I’d wait until I had a new roller and replacement bolt with (proper washer) gasket.
Thanks
Dave
I could probably make you some on the lathe. I should have some delrin stock to make it from.
You can find them at RT specialties. They specialize in old mopar small parts.
