76 Valiant headers
mopar440_82
MONC baby!!!
Oregon
Summit racing has small block A body hooker headers..but they say won't fit with power steering.. any feedback on other choices? :banghead:
Which set were you looking at? Everything I checked on their site would work with power steering. Checked Hedman, Patriot, Summit, Hooker Comp, and Hooker Super Comp. You need to click on applications to get the info.
Direct from Summit's online catalog...
Make:PLYMOUTH
Model:VALIANT
Submodel:BASE
Beginning Year:1976
Ending Year:1976
Engine Type:V8
Engine Size:5.9L/360
Engine Family:Mopar small block LA
Drivetrain:RWD
Engine Swap:No
Power Steering:No
Power Brakes (application):Yes
Air Conditioning:Yes
Standard Transmission Column Shift:Yes
Standard Transmission Floor Shift:Yes
Automatic Transmission Column Shift:Yes
Automatic Transmission Floor Shift:Yes
Footnotes:3 - Must modify stock exhaust to retain catalytic converters.
8 - Will not fit with A.I.R. injection pump.
22 - It may be necessary to raise the column cross shaft linkage by rotating the mounting brackets on frame and transmission 180 deg.
240 - Will NOT fit vehicles with power steering.
:violent1:
Gonna just use the stock manifolds for now, and save some greenbacks for either TTI or Doug's... just want to get it back on the road again:burnout:
Once again, Grumpus, you have opened my eyes! Hedmans look like they will fit the bill nicely:prayer: thanks, sir!
