I have aquired a 78 Dodge 2wd it was a 1ton but the orginal rear blew up and a single rear wheel rear went under it. It has a 440 automatic 4.11 reargear runs good doesn't have alot of rust, floor boards solid. The most rust is on the roof but it looks like surface rust and alittle starting on the cab corner. rear fender wells aren't rusted i don't have the flares. The bad. The front seat on drivers is tore up from use. the wireing is messed up inside. who ever owned it before me hacked the wiring. it runs and drives but you have to have a power wire connected to a wire on the ignition harness. the engine leaks oil out the valve covers and Haven't had time to fix either one. I'll knock 100 off of the price if i can switch the front hubs to single instead of dually. would like to have them for another project but not a big deal. also i have the front bumper up for sale so if it sells before the truck then the truck won't have that bumper i can put a different one on though. I'll also part it out if theres enough intrest in it as the truck is in iowa and i'm in wisconsin so it will be hard to tear apart. asking 1000 obo. any questions Pm me. Thanks
