Im putting together an 8 ¾ center section using the 489 case. I have a 35 spline spool with new carrier bearings and will install any gear ratio that you want up to a 4.86 ratio (not the pro-gear) using new inner and outer pinion bearings and races and a new Ratech #6102 front seal. Id like to get $500 for the center section when fully assembled, plus shipping. Unfortunately, the only pinion yoke that I have is the smaller 7260 series unit. I do have a 10-spline Mark Williams billet yoke #39016 that uses the 1350 series U-joint that can be used. I would like to get $100 extra for that if installed. As an option, I can also install the crush collar spacer for whatever it costs to buy. I already have the 489 case cleaned and painted along with the new carrier bearings pressed onto the spool.
Ken
Edison, NJ
Ken
Edison, NJ
