8 1/4 - 8 3/4 Backing Plates
Richie
Kelowna BC Canada
I bet they wont but will backing plates for your brakes on an 8 1/4" rear end fit on an 8 3/4" rear end? Thanks.
Yes they will, except for the A-body 8 3/4 unless you convert to the same axle offset as the 4.5" bolt circle axles. The 9 1/4 brakes will also fit with the same rules. This is a good place to find 11" drum brakes off of trucks.
