curtis6592
is this a 8 1/4? any other info about it woud be great too. if you can make out any numbers on pic.
Unless your 340 is making over 450 hp the 904 will do fine. A good Trans-go kit should be installed to make it shift better. They also extend the life of the trans quite a bit by eliminating slippage. If it has better than stock friction plates and bands it'll take even more.
trans-go,site to the kit or anything? i have been thinking of a trans kit but didnt come across any recommended companies making them for the 904. are there others that make them that people recommend?
i already got a warmed over 340 in the car just gotta get the 7.25 out of the car before it breaks im tired of taking it easy.do you think the 904 would be strong enough or should it be a 727. i have a 727 i just need to rebuild it along with the rear.
