Max right now, I have the largest tire on the back that the stock suspension will allow, though they are my dads tires/wheels from his roadrunner I will be buying the exact same size tires for my magnum 500's
The factory take outs I have seen on ebay have "Dana trac loc" cast on them. I just think the mopar performance part is probably the same thing. Made by Dana with a MP part number on it. I can't find any 27 spline so I'm not positive, but the 29 spline ones Dana.
being an 8.25 newbie where can i get the 29 spline axles for my a body rear? and is the jeep discs an easy upgrade?
I have no idea what size tire at the moment. I don't know what size tires are on my car at the moment, I will have to check.
I'm sure you could order custom length 29 spline axles for you rear but it would much less just to keep the 27 spline setup. If you don't have a 8.25 already and want disc brakes, posi, and heavy duty and are looking for a donor then the explorer 8.8 is the way to go.
Tires are going to be, 266/60R14 102S
there is no such thing as a 266/60-14
try again
hahah 255/60/15s are on the car right now no need to be so testy....
