8 3/4 axle adjuster pass or driver side?
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I did search and I did look in the FSM (I did not read every page of either)
My recollection is the adjuster goes on the right side when looking through the front windshield from inside the car.
And yes I know it really doesn't matter which side it is on.
The adjuster is only on one side so therefore it does matter which side it goes on as the adjuster is only on 1 side. Factory it is installed on the passenger side. I’ve seen lots on the drivers side though. Kim
I have also seen them on both sides and they appeared original. I'm like you. I don't think it really matters which side it's on.
