8 3/4" axle bearing replacement
70swing
Member
Ottawa IL
I need to replace the axle seals and bearings on my 8 3/4" in my 70 Swinger. Has anyone used the Mopar Performance kit that replaces the end play adjusters?
Does it eliminate the seals also?
I run Green bearings but not the MP set. If they're still selling the first gen style you might want to consider the second gen style with snap ring. Doctor Diff is a good source of these and he explains the difference: Why Green Bearings? - Quality Body Shop Drivetrain
The green bearings have an integrated O-ring to help keep gear lube from leaking but I'd still run the stock axle seals.
