Boost is actually Relative to the Compression ratio and how much heated air is produce and circlated through a Turbo at 9 to 1 CR with 12psi boost you get a effected CR of 16.06 to 1 and the restiction of the intake manifold is only amplified with the more you push through, the only restriction is the longer the pipe the more you lose, much like a water hose on your house when you put your finger over the end of the hose you are resticting the hose and building pressure behide your finger which is creating a stonger faster stream on the oposite side of your finger from the hose, this is what we call a vinturi effect, OK im done with the science and phisics lesson. But in the end Im not Turbo charging my engine Im just Boreing .060 over for a final Cubic inch size of 372 like the 3rd gen Hemi (which is not really a Hemispherical head) but with wedge heads.
