8 3/4 Axles
borlaexu7
Member
I will be building up a 8 3/4.. i havent gotten the rear from my friend yet so i dont know wat case it is.
I was told that if you want 35 spline axles they have to be custom ordered?
I wanted to run a 35 spline spool. So what is the biggest direct fit axle for an 8 3/4 so i can revise my plan for the build up
thanks
thanks
The 30 Spline is the only Stock Option You Have.What are you planning on doing with this car?I drag Race my 68 B-Fish about 250-300 Passes a year and still have the Original Axles in it.I Run a 4.88 Gear with a Strange Light Weight Spool.
I Have an additional Set-Up(Center Section)For Sale if interested.
If you still want to go the 35 Spline Route I am Also a Moser Dealer and can get you Everything you need for the Completion..
E-Mail me if needed..
SS
