Nothing to do w/ the original post, but all wheels do not take the same torque. Weld wheels recommends 95 pounds for the draglite, and prostar wheels. If u run them at 65 , u might be having to tighten the every run or so .This is from 70 service manual. Suspect 71 would be the sameView attachment 1715169570
They slide at the ends as they arch and de-arch. (for the lack of a better term) The center bolt keeps them aligned in the middle. Because the leaves are arched, they lengthen as they get flat and they do slide. That's why there are pads on the ends of the springs. Because Mopar springs are quite short on the front section most of the sliding happens on the rear section.Do the spring leaves actually slide relative to the other leaves at the center of the spring between the two halves of the u-bolts during the springs range of motion?
I wonder if the housing moves around a bit in the u bolts. I know that if you overtorque the u bolts you can dent/ distort the axle tubes.That's how I understand it as well. So how does over-torquing the U-bolts cause a stiff ride then?
I figured that was the reason for the relatively low torque spec. I never quite understood how over-tightening the u-bolts would make for a rough ride. To me, there'd only be two way- either it makes the spring bind, or it increases the spring rate. I just don't see how either of those could happen.I know that if you overtorque the u bolts you can dent/ distort the axle tubes.
I just installed my Caltracs and mono leafs and they wanted 75 - 80ftlbs. I torqued them to 75 and I can feel the threads and bolts stretching. I found the factory torque spec in my manual somewhere. I think the guys above are correct with 40 - 45.
Nope, is that a must? Calvert racing never mentioned anything or best practice.New 1/2" u-bolts???
Torgued mine to a 100Hello all, rebuilt the 8 3/4 rear end and starting to put it back together. I couldn't find the torque spec for the U-bolts for the housing to the spring. Little help please.
Found that spec on an old chassis's manual I believe
Ya I tightened mine down with a 1/2" impact and let her rattle until I found out I was doing it wrong!Torgued mine to a 100
Very possible it was an old oneIt's incorrect.
Also never collapsed a housing or had au bolt come looseVery possible it was an old one
Make sure the weight of the car is on the axle before you torque the nuts to 40 ft.-lbs.
