1. superchargeddrt
    superchargeddrt Well-Known Member
    2,274
    840
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    12:04 AM
    Hi Guys,
    My buddy Larry wants to put a 8 3/4 into his '64 Barracuda. Does anyone know what length the driveshaft has to be? Thanks for your help!
  2. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
    3,432
    1031
    Dec 27, 2013
    PHX
    Local Time:
    9:04 PM
    904/727/833? More info will help this process.
    Jake
  3. superchargeddrt
    2,274
    840
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    12:04 AM
    Sorry,
    904 transmission.
  4. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    46,792
    31057
    Jan 18, 2006
    Iowa
    Local Time:
    11:04 PM
    Original transmission? It will have the ball and trunion front joint.
  5. superchargeddrt
    2,274
    840
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    12:04 AM
    Won't be the original trans. It will.be a later 904.
    • Thanks! Thanks! x 1
    • Tad
      Tad FABO Gold Member FABO Gold Member
      207
      96
      Jun 19, 2018
      Temecula
      Local Time:
      9:04 PM
      I just did my 65 dart. The length from the back of the 904 transmission to the center of the rear U joint was 57 1/4. I know the barracuda has a shorter wheelbase.
    • ir3333
      ir3333 Well-Known Member
      4,472
      1058
      Jun 1, 2008
      ontario,canada
      Local Time:
      11:04 PM
      Are you sure you didn't have a 904 and 7 1/4" rear? My '69 Dart with 904 and 8 3/4 was 52".
      The later plymouth A bodies had a 3" shorter wheel base than a dart but i don't know about '65?
      • Like Like x 1
      • 66fs
        66fs Well-Known Member
        4,357
        1184
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        12:04 AM
        Darts are longer wheelbase. Barracudas take the same driveshaft as a Duster, 67-69 Barracuda or Valiant, with the same trans and rear.
        • superchargeddrt
          2,274
          840
          Aug 24, 2009
          Pittsburgh, Pa.
          Local Time:
          12:04 AM
          Yes it's a 7 1/4 now but he's going to swap in a 8 3/4
        • MichiganRay
          MichiganRay Member
          10
          2
          Mar 19, 2014
          Michigan
          Local Time:
          11:04 PM
          You need to first install the rear end then measure the from the center of the trans U joint to the center of the pinion u joint. QA1 has the information on how to do it right, on their web page. Check the width. They can be different also. Good luck.
