[SOLD] 8 3/4" Mopar narrowing fixture plug's
jtkaaa07
BossMan
Neenah Wisconsin
Up for sale is a new set of narrowing fixture plug's that are used to keep your housing end's square after you cut and shorten a housing, these are a must have to even get your housing close to square while welding it back together. They are made out of aluminum and have a 2.875" side which fit's into a Mopar 8 3/4 end's and on the other side they are 3.15" which is used if you want to put the bigger style ford 9" end's on your housing, and a set of 3.265 plug's which fit in the place of the bearing's in an empty carrier, all that's needed is a 1 1/4" X 60" piece of round stock which you can get from any steel supplier, and a pair of 1 1/4" collars. Item's are located in central Wisconsin, I am asking $75 plus the ride, which is a steal if you look around.
Thank's Jeff
