Hi Folks
So, I've removed the pinion nut, yoke and seal and I want to clean the front pinion bearing of the crud that got in there when pulling pulling the seal. The book says that the front bearing should just drop out when inverted.......It doesn't.
I have tried prying up on it with a couple of screwdrivers and no go.
So, am I going to have to pull the carrier in order to press the pinion shaft out to get this bearing off, or is there a trade secret out there that would help? I really didn't want to dick around with those adjusters putting it back together.
The unit is a 1971 sure-grip with a 741 case and 3.23 gears.
Thanks
Thanks
