[WANTED] 8 3/4 rear end
dwak
burke
Rating - 0%
0   0   0
Im looking for a 8 3/4 rear end with the small bolt pattern and bigger gears for my 76 duster im located in south dakota thanks
I have a complete, drum to drum 8 3/4 setup with a 489 case, 4.10 gears and sure grip differential. Not cut or modified.
Just curious, the 76 cars had the LBP setup front and back from the factory so why do you want the SBP for the rear axle?
I need LBP!
Please pm me if he's not interested. I need to replace my 7.25
Uncle took the disk brakes off the front for his so he have nicer brakes and the bigger bolt pattern before i got the car from him but we put his old rims on old slots with the small bolt pattern so i would like to keep them instead of trying to fine a rim that i can get in both sizes or going straight to a full disk brake conversion and getting new everything
