Island67DartGT
Active Member
I have an 8 3/4 rear housing from a 71 Challenger. Bare, no 3rd member or axles. Paid $100 CDN for it. I also picked up a pair of original A Body axles that came from a 68 Dart GT. Paid $150 CDN for the pair, complete with bearings. These axles are drilled with both 4 in. and 4.5 in. bolt patterns. I know I need to have the housing shortened and spring perches moved inboard.
What is the exact measurement needed for shortening this E Body housing? Flange to Flange (meaning, where axles and backing plate mount) I know the spring perch distance is 43 inches. But not sure on the Mounting Flange to Mounting Flange distance. From what I've read, I can't rely on measurements from the original 7 1/4 rear end as it seems different from mounting flange to mounting flange. Also will the E Body perches fit my spring center pin? Or will they need to be plugged and drilled to 1/2 inch diameter?
Once done, this will be going into my 67 Dart GT to replace the stock 7 1/4 rear. Also would like to know what backing plates from what year and make of car will work to convert to at least 10" x 2 1/2" drum brake setup? Maybe 11" once I find some 15" rims.
