8 3/4 rearend questions
phf
Midlands, SC
what is the width difference between the a-body 8 3/4 and e and b body one?
65 -72 abody 55.6 inches spring perches 43 inches
B-body, 62-70 59.2 inches spring perches 44.0
B-body, 71-72 62.0 inches spring perches 47.3
E-body, 70-74 60.7 inches spring perches 46.0
Hope this helps!
Here's some stuff.
so i got my hands on a b-body 8 3/4 housing thats an inch wider than an a-body one overall. i have a choice:build a completely new rear with new axles, and brand new everything third memmber. or i can buy used parts and rebuild them. suggestions please....
im looking at 373 gears with posi. the rear end needs to withstand 400-550hp smallblocks. also should i have it shortened to work with the relocated springs and minitubs? how far should i shorten it? where would i get the wheels with the negative offset?
