[FOR SALE] 8 3/4 rearend
Douglas Smith
Member
Shelburn
Rating - 0%
0   0   0
8 3/4 rearend 741 case with 3.23 gear. big bolt pattern. complete rearend. It was in a 68 Barracuda. $750
$750
Yes it big bolt pattern. 5 by4.5 Not sure on axles but look stock. I need to get to storage and measure it. But it was in a 68 Barracuda and I believe with stock spring location.
Were the axles OE that were drilled?
Yes looks OE. Some people are saying they didn't have a 8 3/4 big bolt pattern for a body. This is big bolt pattern and looks all stock. Center section has been replaced. Center section is not original to rearend. I pulled it out of a 68 Barracuda
I would assume by the spring perch dimensions that it is in fact a 66-67 B body rear end!! Shoot a closeup pic of the brakes, preferably with the drum off!!
More than likely a 66-67 B body housing, which actually work well in Dusters/demons. Allows for big bolt pattern and 10x 2.5" brakes, however it is not a $750 rear, more along the lines of $200 with an open differential.
Here's dimensions -- DELETED __ IT WAS WRONG --
