65GT
Active Member
I know pinion gears are matched to the ring gear but has anyone ever used a different ring gear without changing the pinion?, and if so how'd that go?
The reason I'm asking is, I picked up a clutch type sure grip yesday and a ring gear was still attached and it just so happens I have a pumpkin with the same ratio but with a chipped ring gear and immediately thought about switching good for bad.
Thanks
Thanks
