[WANTED] 8.3/4 sbp backing plate
V8 Sam
United Kingdom
Using a body small bolt axel shafts in my narrowed b.body axel.
Turns out I need sbp 8 3/4 backing plate so the offsets are correct
So that's what I'm after Ideally for 10 inch drums
MUST BE WILLING TO SHIP TO UK.
Thanks
To help in your search, the B-body 6 cyl cars with a 7 1/4 also used that same backing plate.
Urgh I can't keep up with the hundreds of different combinations.
7 1/4 B body big bolt? backing plates are the same as abody 8 3/4 sbp backing plates?!
Should your newest search not pan out, I’ve got a pair of SBP backing plates for the 8.75. They have excellent shoes, springs, levers and wheel cylinders. I have no problem shipping to the UK or any other place in the world for that matter. PM me if interested
Yes! The 6cly cars had them with the wimpy 10" brakes. Big bolt pattern wheels, but, that's beside the point. The brake shoes were the same size. I'm talking about the '65-7 B-bodies now, and just the 6cyl's with a 7 1/4 rear.....the '64 and earlier are different, as well as any of the B's with an 8 3/4.
